remote starter switch
I just assembled a remote starter switch. I want to know where each alligator clip goes. I have a 2002 Toyota Tacoma.
Thank You, moish |
The assembled remote starter switch I made is comprised of an ignition start switch, 2- 12ga. wires each with an alligator clip attached. I want to engage the starter w/o turning the engine over. I do not know what 2 terminals to place the clips so that when I "hit" the button, the starter engages but the engine doesn't. Again this is for a 2002 Toyota Tacoma.
Thank you, Moish |
back in the day
Just wire in a switch into the ignition circuit. When you want the engine to crank but NOT start just throw this switch to off.
That way when she says lets go home you throw the switch and claim the truck won't start and then etc..... vicrod |
Thank you, but that isn't the "application " I was refering to. My application is to have the switch in you hand. Thanks anyway. Moish
Ok, I get it now...... you want the starter to engage, but not start the truck....... Colbat's dia is right on.
Is this a manual truck? I assume you want to put the truck in rev and use the starter switch to back it up to hook up a trailer? |
I believe (if you have a manual trans?) you might be able to use the relay terminal but that will not work w/alligator clips w/o making jumpers for the female terminals to connect to the remote switch. |
The Toyota Tacoma has an automatic transmission.( No, the remote won't allow me to hook up a trailer).
Wouldn't one clip go to +bat terminal and one clip to the "S" or ignition switch? I would then have to put key into "on" position but not start up engine. I would then hit the Remote starter that I made? On YouTube this was done EXCEPT the guy DIDN't show a key in the ignition being used. This is the part that doesn't make sense.(Circuit closed w/o key in "on" position, correct?) Thanks for trying to get me an answer, Moish |
If you are trying to make a push button starter using the key to turn it on/off..... use colbalt's dia. If you are trying to make a keyless push button starter then it's way more complicated.
No i'm not trying to make a push button starter. No i'm not trying to make a keyless push button starter.
Picture this, a guy doesn't have anyone to turn the key on by he needs to engage the starter and not turn over the engine while he is underneath the car. He could press one of those REMOTE STARTER SWITCHES from Autozone that costs around $15. (I made my own but need to confirm how the alligator clips hook up to battery and solenoid) Thanks again for trying, Moishe |
| remote starter | bracketeer | Electrical | 7 | 04-20-2011 07:56 AM |
| Remote Control Light Switch? | Dave57210 | Garage - Tools | 6 | 04-16-2011 12:47 PM |
| How to make remote starter | 350pano | Electrical | 8 | 05-12-2009 05:22 PM |
| Remote starter?? | sexypizzaman | Electrical | 2 | 12-16-2008 06:00 PM |
| Remote Kill Switch... | AmericanPackMule | Electrical | 5 | 09-23-2008 08:03 AM |
