removal & installation windshield
Im getting started on my 84 monte ss. There is rust spots around the windows on the car. I have never removed a windshield before(at least not on purpose) I dont wont to damage the glass. What do i need(special tools?) to remove and reinstall the front and back windshields. Also the little side back windows need removed also. I have already took the trim off around the back and front windows.
Thanks Aaron |
I have been wanting to do the same thing, but from seeing a few other quite mechanically inclined people pulling off the windshield swap for the 1st time its quite a task. Especially trying to reuse the window without cracking it. I'm not saying don't try it. Just the funny things they say if they could do it again. One guy mentioned it took him for the first time 8 hours to finish and saved himself $60. He said if he could do it again, it would have been by someone experienced plus to help show him how its done and help make him faster at it. But I think its still worth a try. I'm still too afraid to pull it off. Next project I will. Mainly a pride thing that I did it all myself.
Heres the back window of an 82 not worth mentioning that I took off. Not much older than yours. But theres some rust too. ![]() Sorry I couldn't take you through the process, and the back window I used a molding remover like a thick L shaped screw driver to gently take out the thick rubber seal thats between the window and metal. It was hard for me to search on a how to guide for replacing windshields. I did find a place where you can at least see what tools and adhesives you'll need. hth http://www.windshieldsupplies.net/xc...-p-1-c-75.html Last edited by Danny G.; 05-05-2006 at 03:08 AM. Reason: tool site |
Thanks for the help. I hate to have to haul the car somewhere to have it done. Also, im like you. I want to do it all myself.
thanks aaron |
Sam
I also recommend having a glass shop remove them. They are not "that hard" but, it is usually pretty good money spent to have someone else do it if it is not your bag.
If you do go for it, you can get a "cut out knife" at the autobody paint store that works like a charm on the rear glass. It is tempered and pretty darn hard to damage. I have cut out MANY of them using this knife. The front, that is another story. Again, I have cut out MANY of them using a cut out knife, I did this before I was told you could "Never" cut one out without breaking the glass. Darn, I didn't get that memo until I had cut out MANY of them without breaking the glass. But I am told it can't be done. This is what I would do, IF, I was to go ahead and do it myself. I would get a cut out knife, remove the rear one first. Just let the knife do the cutting of the URETHANE and NOT force it thru letting it bind into the edge of the glass. Make the blade "float" THRU the middle of the urethane. After doing that you will have some practice and experiance enough to know whether you should get anywhere near that windshield. At that point, either go for it or have it done. OPTION: Go for it and cut the windshield out, be damned the breakage and then replace the glass with new which is what you should do anyway! You have a 20 year old windshield, it is not perfect, full of little chips and marks. After painting your car, there is nothing like looking down your new shinny new painted hood thru a new crystal clear windshield. I have replaced many with new just for this reason. Brian |
Thanks brian, I think im going to give it a shot. Worst that can happen, I would have to put a new windsheild in. What about the little side glasses on the monte carlo. The trim is different on them.
Thanks brian,
Let me know what he says aaron |
| Basic of Basics - Windshield Installation Kits | firebird_red | Body - Exterior | 15 | 11-26-2005 09:00 PM |
| 1985 Monte Carlo Windshield trim and rear windshied trim removal | ChrisMiddleron | Body - Exterior | 3 | 01-14-2005 06:20 AM |
| Windshield Installation | Stude Dude | Body - Exterior | 0 | 03-05-2004 08:28 PM |
| Windshield seal installation, 37 Ford Coupe | Ted's37 | Body - Exterior | 3 | 08-14-2003 08:51 PM |
| valve spring installation and removal | fordracing | Engine | 2 | 04-17-2003 12:49 PM |
