We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-26-2009, 03:51 PM
dmcphee07Si dmcphee07Si is offline
remove all the old seam sealer?
i am stripping down my early 80's dodge to bare metal. There is a ton of seam sealer on these trucks and i was wondering if i should remove all of it or if its ok to leave some in the non problem areas? i am digging it all out on the winsheild drip rail because thats where these trucks rot but what about in the body lines between the different sections? its all original paint and the sealer looks good except a hair line crack throught it. I am just thinking it might be a PITA to remove and then re-apply after the expoxy and get it to look good again, as the body lines are fine. Any suggestions or help would be great, also whats the best way to dig/remove old seam sealer?
Old 07-26-2009, 05:27 PM
cjperotti cjperotti is offline
Your right, it is a pita. Been there, learn my lesson. If nothings wrong in those areas leave it alone. Fix only those areas that need to be addressed.
Old 07-26-2009, 05:44 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
i have been told that you can burn it out with a small torch
Old 07-26-2009, 05:49 PM
danny_g danny_g is offline
I agree with perotti... I'd just leave it alone.
Heat will loosen it somewhat. But, you'll still have to get in there and scrape it. It won't just peel off if heated. Like I said, been there.
Old 07-26-2009, 06:30 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
gunslinger
deadbodyman's barnstar
Wiki editor
Last wiki edit: Stripping paint
Wiki Edits: 11
seam sealer is also expensive...30.00 just to redo the driprails..at least a hundred to do all of it ,not to mention labor and time wasted that could be better spent on the problem areas,If it looks good leave it."fast & firm " works pretty well for me
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "remove all the old seam sealer?"
What SEM seam sealer? glhx Body - Exterior 3 05-03-2009 07:37 PM
Problems with SPI white sealer?? 35prog Body - Exterior 3 04-19-2008 03:03 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 7 02-25-2006 03:18 PM
How much Seam Sealer to use? satexasf150 Body - Exterior 3 10-26-2005 11:58 AM
