Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - remove choke from quadrajet?
Old 10-16-2009, 10:08 AM
Brimstone Brimstone is offline
You don't say if it's a vacuum or electric choke. If it's electric then you can just remove the housing, but if it's vacuum then you need to plug the vacuum hole in the main body (it's where the forward-most support leg fits on the side).
It's not big, slightly less than 1/16" in diameter.
