remove choke from quadrajet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2009, 10:09 PM
1964_442's Avatar
my quadrajet had a non working choke that looks like this:
can I remove the whole choke assembly without having problems like in this picture and leave it that way?
Old 10-16-2009, 01:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes. You will also want to remove the choke butterfly from the air horn- it is counterbalanced to have a normally open position, but I wouldn't trust that it couldn't get sucked closed in an extreme circumstance.
Grind the peened ends of the screws off to make removing the choke b-fly and shaft easier.
Old 10-16-2009, 08:24 AM
1964_442's Avatar
this b-fly? any more i can take off from the choke mechanism?
Old 10-16-2009, 10:08 AM
You don't say if it's a vacuum or electric choke. If it's electric then you can just remove the housing, but if it's vacuum then you need to plug the vacuum hole in the main body (it's where the forward-most support leg fits on the side).
It's not big, slightly less than 1/16" in diameter.
Old 10-16-2009, 07:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That is the one. It, the linkage that runs down to the thermostat, and the lever that attaches the link to the thermostat is all there is to remove.
There is no benefit in removing the air horn like you see done w/Holleys.
Old 10-16-2009, 08:27 PM
definatly remove the plate if removing the other. I take off all the choke parts as well when I race b/c of the chance of them getting sucked or stuck shut is a real possibility.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Holley variant choke questions, carb recommendations Dilbert Engine 1 02-11-2009 07:39 AM
Choke Questions, orvillewho Electrical 2 03-25-2008 01:01 PM
Is It OK To Remove Carb Choke Plate ? leejoy Engine 5 05-29-2006 08:46 AM
