Remove gear function from column? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2010, 03:48 AM
staleg's Avatar
Last journal entry: Home made gear stick
I have a 1990 Chevy Astro steering column that I intend to use on my manual gear equipped hot rod.
How do I remove the gear stick, the "bump" on the column cover that the stick is attached to, and the gear bracket at the bottom of the column?
When I move the stick, the column cover moves with it and the bracket at the bottom also moves. I want to remove all these parts and make a new column cover, but how do I remove them? Do I have to take the whole column apart from the top, or is there an easier way?
Of course, I could just cut away the stick and the cover bump with the grinder and leave the rest in place, since nothing of it would be visible anyway.
But wouldn't such a solution make the rest of the gear parts in the column rattle around, since nothing would hold them in place anymore?
Old 07-27-2010, 01:50 PM
39Hemi's Avatar
20 years ago I did just what you suggest when I swapped a tilt column into a 1980 Buick Skylark with a floor shift. There was a gear selector on the tilt column that I didn't need so I pulled the lever, ground off the hump, patched the hole with some aluminum tape and bondo and 20 years later it's still working fine.
Old 07-27-2010, 08:12 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
absolutely right... did a very similar mode myself.. good clean easy fix.
Will work to get rid of the ignition switch also, make sure you disable the steering wheel lock.
Old 07-28-2010, 01:14 AM
staleg's Avatar
Ok. Thanks!
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 03:56 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 04:50 AM
