remove mcgard wheel locks with no key - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2002, 07:04 PM
Post remove mcgard wheel locks with no key
just aquired a vehicle with mcgard kocks on
the wheels the old owner lost the key and the number card.any sugestions on removing them
would be greatly appreciated.
Old 02-05-2002, 04:15 AM
Post
Most tire/wheel shops have a tool for this.
Old 02-05-2002, 07:15 PM
Post
I have been very sucsesfull in the past by finding an old ********et that all most fits over then useing a biggg hammer pound the socket on the lock. This will normally work. I have even welded a nut to the lock using a welding blanket with a hole in it. Body shops will 9 times out of 10 have a kit just for you problem.
Old 02-19-2002, 03:31 PM
New Member
Post
i'v had good luck with the socket usually a15/16 12 point. also have used my air chisel with a great deal of sucsess. good luck.
Old 02-25-2002, 09:40 PM
New Member
Post
Check your local Parts Store. Orielleys, and Autozone both rent tools for everything. We pay for the tool, and get total refund upon return. This is very cool
Old 03-03-2002, 10:34 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Post
Lost lock lugs…. I don't endorse the following method, but thought I would share it
Back in 1977 I had a buddy who had a '64 hard top Impala. What a great car. Anyway, he had it given to him from his grandparents, he had it repainted yellow and put Cragar S/S mags with big and little rubber.
Well I noticed one day when he picked me up on the way to high school that he had an old steel spare rim on in place of one of the Cragars . I asked what was up.
He proceeds to tell me about how he had a flat tire at home over the weekend and had lost his lock lug socket. He literally beat the center out of the rim with a sledge hammer. Yikes!
Old 03-09-2002, 07:34 PM
Lightbulb
If all else fails, I have used vise grips before and with relative ease removed the lock nut. If it's on a steel rim though the torque will probably cause it to slip. Mags and aluminum wheels USUSALLY aren't torqued as high as steel.
Good luck
Old 03-25-2002, 03:00 PM
New Member
Wink
I have got them off by using a piece of steel pipe that fits over the lock just snug enough to get a good grip. then i just worked them back and forth until the lug bolt snaps. you'll have to replace the lug bolt, but thats easy enough.
Old 03-25-2002, 03:16 PM
Post
Get a sacraficial socket from a pawn shop, about 1.00 that fits a little smaller, hammer it on. Through them a way!!If your wife or anyone else has to struggle your outfit will probably sit awaitig you. If they want your rims&tires locks offer little deterrent, They are hard to keep track of, I used to use them-Never again. Just my 2-cents(It's not worth much)
