Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - remove swirls and lite sand marks
Old 07-03-2012, 05:41 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Originally Posted by tech69 View Post
if you have sand scratches in it you should go back to square one of compounding, whether that be foam or wool. This is if your scratch is 1500-2000. If it's something below that you should wet sand the area with 1500- 2000 then step up to 2500-3000.
The biggest mistake I have seen in cutting and buffing is people going off to the next stage before they're even done compounding. You generally want to get everything in the compound stage or damn close to it. This makes the following steps very easy.
Also very true and I'm guilty of it myself....always in a rush to get the drudgery of buffing over with...
What happened to the spell check button anyway?
