Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Remove upper control arm - Bolts welded.
Old 07-25-2012, 03:59 PM
Chucky5150 Chucky5150 is offline
Last journal entry: Dual 13 inch fan install
Originally Posted by ericnova72 View Post
Sorry, but you have no choice but to pull the headers to remove the A-arm , unless you can get in there and grind that weld off with everything assembled.
I'm thinking of trying a Dremel tool with this attachment and a small cutoff wheel.
225-01 Flex Shaft Attachment / Model: 225-01
Guess I should look into getting new bolts while I'm at it.
"If you give a mouse a cookie" should have been "if you give a guy a classic car".
