Remove upper control arm - Bolts welded. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 12:15 PM
Last journal entry: Dual 13 inch fan install
hey guys need some advice here.
1967 El Camino
I'm guessing that the upper control arms didn't come welded from the factory. How is the best way to go about removing the upper control arm? All four bolts (2 on each side) are welded in place. I really don't want to remove the headers to get the control arm off. Those were a real pain in the butt to get in place.
Thank you.
Name:	2012-07-25 13.03.32.jpg
ID:	67001   Click image for larger version
Name:	upper control arm.jpg
Old 07-25-2012, 03:52 PM
ericnova72's Avatar
More for Less Racer
The tack welds on the bolt heads are not factory, looks like someone got in there and welded them because the original knurl under the bolt heads must have gotten stripped or the hole slightly egged out.
Sorry, but you have no choice but to pull the headers to remove the A-arm , unless you can get in there and grind that weld off with everything assembled.
Old 07-25-2012, 03:59 PM
I'm thinking of trying a Dremel tool with this attachment and a small cutoff wheel.
225-01 Flex Shaft Attachment / Model: 225-01
Guess I should look into getting new bolts while I'm at it.
"If you give a mouse a cookie" should have been "if you give a guy a classic car".
Old 07-25-2012, 10:34 PM
put up or shut up
try a tungsten carbide bur bit. They're perfect for that.
86 G Body rear control arm upper, how to remove frozen bolts? bubbahotep Suspension - Brakes - Steering 4 06-25-2012 05:54 PM
79 Trans Am upper control arm bolts.. JKear Suspension - Brakes - Steering 2 12-09-2011 03:19 PM
howto remove upper n lower control arm bushings??? crankshaft3rd Suspension - Brakes - Steering 8 02-27-2011 08:36 PM
upper control arm runn141 Suspension - Brakes - Steering 1 09-12-2009 08:18 PM
upper control arm axle bushings, remove/install ss396si Transmission - Rearend 1 02-16-2005 05:57 PM
