Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Remove windows inside of doors Help!
Old 06-24-2003, 10:32 PM
outlaw17's Avatar
outlaw17 outlaw17 is offline
ChrisMiddleron , you need to take the door panel off then just look at how the glass is attached to the regulator , some are bolted and you just unbolt them tip the glass to get it out of the channels and then lift out the top , and then some get tricky but just look close at how it operates , roll it down and up a few times watching what its doing and you should be able to figure it out .
***** GO OILERS GO *****
