Removing 1953 Chevy Suburban dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2005, 08:37 PM
Sly's 53 Suburban's Avatar
Last journal entry: Completed the side window installation
The previous owner cut a hole in my lower dash for stereo installation. Kinda sucks considering the dash already had a spot for a stereo. I'm debating removing my hacked dash and installing a donor dash. Does anyone have an assembly manual or something that detail's the removal process? I could repair my dash but, if replacing with a donor isn't much tougher, I'd go that route. Thanks in advance.
Old 04-27-2005, 08:56 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
If I remember correctly the dash is made as a part of the body structure and is welded in. Would be easier most likely to repair what you have. Member Centerline has a nice website regarding modifying the dash in his '53 Chevy pick-up http://www.hotrodsandhemis.com/. Look for the button on the left for the 1953 Chevy truck.
Good luck with your Suburban. I'll be starting on my '48 Suburban after the current project is finished.
Old 04-27-2005, 11:31 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
they are spot welded in & are a PITA to remove but a little less of a PITA to install. you'll need thin/sharp chisels or a drill & bit to either cut it out or to remove the spot welds.
i used a chisel, but then i had NO CHOICE since i didnt know what i was getting into & had just drove 12+ hrs to get Large Marge (my bus). just take ur time IF you decide to remove it. i "HAD" to put one in mine since the was NONE. if i had a choice on what i WOULD of done, i would 1st try to repair yours.
always remember to use the KISS method...
Keep
It
Simple
Stupid
Please don't take that the wrong way but its true, IF you can do it a simpler way by all means do it.....joe
Old 04-28-2005, 12:14 PM
Stinkin_V8's Avatar
Suburbanite Member
Ya - it's spot-welded in and would be really tough to get out. Even if you got it out, removed another one from a donor, you'd still have to repair the holes you drilled out for the spot welds. Maybe you could patch in a panel from another truck? Should be pretty easy to find one. I've got the assembly manual, there isn't really enough detail in there for what you're looking for.
When do we get to see some pics of your '53? I'm hoping to get back to my '52 soon. As long as I get mine done before Advanced Design, I'll be happy!
When life hands you lemons, ask for tequila and salt
Old 04-28-2005, 06:13 PM
Hey that's right. Stinkin'-V8 and I are having a competition to see who gets their Suburbans built first. He is way ahead and I am sure will finish first.
Old 04-28-2005, 08:00 PM
Thanks for all your feedback, it's much appreciated. I haven't figured out how or where to post the pictures of my project. I've searched the Hotrodders site a little, but haven't found how to do it yet. When I do, I'll post up a bunch of pictures. I look forward to seeing your Suburban pictures as you guys progress.
Old 04-28-2005, 08:21 PM
Sly,
It is good to run into another Suburban fan. Not many out there. Stinkin'V8 is way more technologically advanced than I and even has his own website. Check under frame swaps in this forum at the beginning of suspensions.
Soon as I get the '35 Master Coupe finished will start on the Suburban. Then maybe I'll learn to load pictures too.
Have fun with yours!
Old 04-29-2005, 08:21 AM
AD
It would be cool to get as many old Suburban's out on some type of rod run. It'd be interesting to see how many there truly are out there.
Old 04-29-2005, 08:38 AM
Sly,
Sure would. I don't run into very many at any of the rod runs. Tom Hurd of Haulin' Hot Rods has put a club together for truck gathering at the rod runs http://www.haulinhotrods.com/ClubNews.jsp though they are in the East.
Old 04-29-2005, 11:21 AM
Stinkin_V8's Avatar
Suburbanite Member
Hehe.. AD is selling himself short. I may have started first but that doesn't count anymore when I haven't touched the thing for a year and a half. It should be a good race and if I recall correctly, the loser has to drive their Sub to the winner's house for beers? No small task, we're talking around 1500 miles.
Maybe we should make it so the winner has to come over and help me finish mine?
I'm hoping to have my wife's little hotrod on the streets in July, which frees up my time (and some space in the garage) for the Suburban. You can check out my lack of progress here
Old 04-29-2005, 12:32 PM
Aye, as long as it is some good Canadian beers! Yep winner goes and helps. The 1500 mile drive would be a good validation of the "winners" ride.
Old 05-01-2005, 10:42 PM
Hey, I put my journal together. Here is the link. http://www.hotrodders.com/forum/jour...ge=1&reverse=1
I hope it works. I have all kind of pictures. It doesn't show up under the right side of my post for some reason.
Old 05-01-2005, 11:02 PM
Sly,
Thanks for sharing your project journal. Looks like a pretty solid Suburban. Way cool!
The hole in the lower dash looks like it would be much easier to fix than replacing the dash.
Have fun!
Old 05-02-2005, 04:15 PM
Stinkin_V8's Avatar
Suburbanite Member
Looks good, Sly! Keep it up!
Old 07-06-2005, 05:28 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
is the dash from a 53 bel air spot welded as well? cause i'm having a heck of a time trying to get it out
1953 chevy truck hood jstgtnstarted Body - Exterior 7 04-23-2008 05:55 PM
1953 Chevy Chop top? Harvi53 Body - Exterior 5 06-11-2003 08:08 PM
1953 Chevy interior Mikey Interior 3 12-17-2002 10:54 PM
91 chevy dash and doors bluechev4x4 Interior 1 12-12-2002 03:19 PM
55 Gmc dash to 55 chevy dash stubbys 55 Interior 4 12-03-2002 10:30 AM
