Removing a 2.8/700r4, Install V-8 with 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2007, 09:22 PM
230FIREBIRD
Transmission question?I have been reading posts about switching fro m tpi/tbi to a carb.Thay say that the converter will not lock up.I am removing a 2.8/700r4 and replacing it with a 305 out of an 84 bonneville.I have a carb,not electric carb,and vacume advance distributor.I also have a 700r4 out of an 86 firebird.I was not going to remove my ecm,so is my tranny going to "lock up" like it is supposed to.All this is going in my 87 firebird.Any comments would be welcome.Thanks,John
Old 09-16-2007, 08:15 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Best to ask about your converter in the Transmission forum.
Old 09-16-2007, 10:15 PM
Wiki Edits: 49
Moving to transmission forum.
Old 09-17-2007, 06:25 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no the trans will not lock up the converter correctly. You are removing all the inputs for the computer..
You are removing the TPS , electronic distributor. These provide information to the computer for the car.
Do you have an electronic speed-O or a cable driven speed-O?
Old 09-17-2007, 05:17 PM
xbody69's Avatar
CARNUT
700r4 problem.
Depending On Your Skill Level With Electrical Issues, You Can Go To Summit Racing And Get The Tci Standalone Wiring Harness For The Lock Up Or You Can Go To Your Local Library And Find The Wiring Diagram For Your Car And Find The Circuit To Hook Into. They Usually Work On A Vacuum Switch For The Tranny To Lock And Unlock The Converter. As Well As Being Tied Into The Brakelight Switch.
How to install a chimney for a wood heater rusttorod Garage - Tools 31 11-06-2006 08:56 PM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 02:17 PM
700R4 install Blackdog Transmission - Rearend 2 04-30-2005 11:18 PM
700r4 stock stall? Caesar_Mikey Transmission - Rearend 1 03-27-2005 05:52 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
