Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing a 2.8/700r4, Install V-8 with 700r4
Old 09-17-2007, 05:17 PM
xbody69's Avatar
xbody69 xbody69 is offline
700r4 problem.
Depending On Your Skill Level With Electrical Issues, You Can Go To Summit Racing And Get The Tci Standalone Wiring Harness For The Lock Up Or You Can Go To Your Local Library And Find The Wiring Diagram For Your Car And Find The Circuit To Hook Into. They Usually Work On A Vacuum Switch For The Tranny To Lock And Unlock The Converter. As Well As Being Tied Into The Brakelight Switch.
