Removing adhesive - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2005, 07:21 PM
Mightymouse's Avatar
Chevy SS
Removing adhesive
Whats the best thing to use to remove the adhesive that's left over after you peel the pinstripe off?
Old 05-23-2005, 06:59 AM
dei8fan's Avatar
Registered Brain Surgeon
Use one of these....It works slick and dosent hurt the paint.
http://www.mytoolstore.com/astro/astmat06.html
Old 05-23-2005, 09:23 AM
Chevy SS
lol im lookin for something a lot cheaper.. And i dont know if it matters or not but the car was repainted less than 3 months agao but i decided i dident want the pinstripe so i took it off
Old 05-23-2005, 10:20 AM
302 Z28's Avatar
3M makes a fine trim adhesive removal solvent. Find it at any auto paint supply shop. Try mineral spirits and see if that works.
Vince
Old 05-23-2005, 10:44 AM
mrcleanr6's Avatar
usually most solvent base wax/grease removers work good and wont harm the paint.
Old 05-23-2005, 12:23 PM
Chevy SS
Will mineral Sprits harm the paint??
Old 05-23-2005, 01:47 PM
Adhesive cleaners and wax and grease remover work fine. 3M also makes a stripe and woodgrain remover that works well.
Old 05-25-2005, 11:37 AM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
careful if you use mineral spirits, you could take some of the clear off if the paint isn't that old.
Old 05-25-2005, 12:01 PM
mrcleanr6's Avatar
mineral spirits wont begin to harm the clearcoat. you can wipe down basecoat with it a half hour after spraying without harm. mineral spirits is about the most mild solvent there is. i usually use it to wipe down my delicate airbrush work before clearing, anything else would harm it.
Old 05-26-2005, 09:27 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
I Used the 3M pinstripe and Woodgrain remover to take off a one inch wide pinstripe that was on the bumper cover I purchased for the project. The bumper cover probably had that stripe on it for 10 years but I sprayed on the 3M waited a bit and peeled off the pinstripe then I sprayed more on and wipped off the glue. Through it all the paint was left untouched. It works great.
Ric
Ric
Old 05-27-2005, 12:02 PM
Would you have the 3M part number for this stuff by any chance?
Thanks,
-Bob
Old 05-27-2005, 08:51 PM
Ratchet's Avatar
08907 is the number
Ric
Old 05-30-2005, 01:14 AM
08907 is the number
Cool, thank you.
-Bob
Vinyl Adhesive J Cal Body - Exterior 7 01-31-2013 12:24 PM
Adhesive Floor Boards tay Body - Exterior 5 03-07-2005 08:04 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
removing camaro engine by removing sub-frame bullheimer General Rodding Tech 7 04-23-2004 02:46 PM
need help, removing ac system on 91 mustng jfmustang General Rodding Tech 1 04-19-2003 04:20 AM
