removing amp/installing volt gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2009, 04:03 PM
got most of my wiring done. not sure when changing over to volt meter gauge. not sure its working,no light.that may be just a bulb. 2 studs that have 0 and G on them.actually bracket that holds gauge to dash goes on these studs. one bottom stud says I. my harness has a red wire that says to power gauges up. i ran the red wire to this I on the volt meter gauge then to I+ on all other gauges. i think they will work all other gauges.oil.water,gas have a wire off them to the sender,all done. is this all that goes to volt gauge is this red power up gauges wire? can i test this gauge across my batt. maybe? 1 side to -/ 1 side to +. thanks
Old 02-11-2009, 07:22 PM
302 Z28's Avatar
The "I" terminal gets 12 volts when ignition is on. You can use the same to power the other gages "I" terminals. Run your power wire first to the voltmeter "I" terminal. I prefer to run a separate wire from a junction close to the batter or fuse block for power to the volt meter, this gives a truer indication of voltage.
Vince
volt gauge is spazing elcaminodragster Electrical 51 06-05-2008 05:42 PM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
Gauge wiring on 6 volt to 12 volt JeffB Electrical 6 10-28-2006 09:28 AM
Volt Gauge pops79 Electrical 3 05-28-2006 03:47 PM
Volt Gauge hook-up 66pontiac Electrical 2 09-12-2005 06:51 PM
