removing axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 02:07 PM
removing axle
I am trying to remove my axle on my 61 chevy
I got the drivers side off by taking the 4 back bolts off and used a sliding
slam hammer that I rented from Autozone. Came off with just a few slams
The passenger side will not budge. Is there something different on the pass
side? Can I put heat on it where the bearing race sits?
Tired of slamming
Marcus
Old 09-17-2010, 02:31 PM
poncho62's Avatar
Wiki Edits: 5
Nope....Same deal on both sides....its just stuck..........I guess a little heat wouldn't hurt as long as you are replacing the bearing and seal anyways......are you?
Old 09-17-2010, 03:04 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Poncho already replied
Old 09-17-2010, 08:44 PM
i was not planing on replacing the seals but if I heat it up I most likely will mess up the seals. I'm pulling the axle so I can replace the gasket on the deferential case which was leaking.
Old 09-18-2010, 12:31 AM
SSedan64's Avatar
I usually attach a chain to 2 studs & run it through a spare rim connected with a bolt/washers/nut and snatch works way better than dent puller/slide hammer.
Old 09-18-2010, 06:33 PM
i drilled a small hole it the cover and put penitrating oil on it and let it set over night. Today I placed a 25 lb. barbell weight on the slam hammer and beat the H?"** out of it and it never budge.
I only have a little torch that one would use on plumbing and don't think that is not enough heat. I will let it soak some more and if that does not work I have to call a bud to bring in his torch.
This is getting old
Broken axle mrdreex Transmission - Rearend 35 07-22-2010 12:39 AM
drop axle help Highcrest1 Suspension - Brakes - Steering 6 05-03-2010 10:02 AM
Removing Rear Axle Bearings - 1972 Nova leejoy Transmission - Rearend 8 10-19-2006 07:52 PM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 04:20 PM
determining right dropped axle adtkart Suspension - Brakes - Steering 4 08-12-2003 05:48 PM
