Removing bearings without a press.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2005, 03:45 PM
zipfactor's Avatar
Last journal entry: Just starting
Hey all,
I was wondering how to remove bearings off of the old hub assemblies on my 1995 dodge avenger. I bought some timken bearings today and i thought that they were the whole assembly and not just the bearings. I would have bought the other assemblies but they are 40 dollars more a piece so, if i could, i would like to remove them if i can. I dont have access to a hydraulic press, so any tips or tricks would be great
Thanks ,
Ben
Old 08-10-2005, 03:56 PM
Parisienne66's Avatar
Well, don't know if you have contact in a machine shop or not, but I went to the shop I always do business with with my Hub assembly and the new bearing, and they gladly press em out and your new ones in for a few bucks. Might wanna try the local machine shop for that, I wouldn't think they'd charge more than the 40$ each so you would still save over the assembled ones...
My bits.
Yannick
In the end, its not that you went were you wanted that matters, but the journee you took to get there that you will remember and cherrish.
Based on Homer's Philosophical writings.
Old 08-12-2005, 07:54 PM
moparx's Avatar
New Member
hay zip. you have a pm.
Old 08-13-2005, 01:12 AM
BFH.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
will these bearings work? 79 Malibu327 Engine 3 01-13-2005 08:59 PM
Repacking Wheel Bearings? oldschoolrods Suspension - Brakes - Steering 5 05-10-2004 06:37 AM
.001 oversize main bearings from factory crshrmn3 Engine 2 01-02-2003 07:46 PM
Alright. One more quick comp lesson 4 me HemmiGremmie Hotrodders' Lounge 13 01-02-2003 07:14 PM
