Depending on which body style it has for balance point: You could put a thick wide plank(s) right through the window openings and use 2 comealongs to your joists.(if the joists are strong!) It won't work if you can't get the plank to fit at the balance point. If it's balance is off slightly, I've put extra weight inside to get it perfect.
Thanks! My joists are only 2x4s but I was thinking of using 4x4s over head and bracing the hell out them. I was also thinking of using 4x4 for vertical posts to support this. The plank sounds good to me. Are 4x4s strong enough for a tudor body or should I look around for larger dimensions.
I used an engine hoist, jackstands, and a piece of 2 x 3 rectangular tubing.
Russ |
I usually use straps through the doors, that way there is no chance of denting things.
Also, a couple of straps into the trunk area keeps things balanced. If you can access your overhead beams, you can hook 4 ratchet straps or come alongs to them, one on each corner of the body. I try to hook to structure on the inside, like the drip rail reinforcing plate and hinge access holes sometimes found on the A pillar. I lift them with my forklift, but the attachment is the same. You can see the straps going into the trunk, and looped under the door. Sorry the pics are so bad, it was nighttime. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
SO ... I just invite a few good old southern boys over ... ![]() ![]() Remove the doors, decklid and most everything you can to make it lighter and then a few friends can lift it fairly easy.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Duece,
In that second pic----kinda wondering whey that younger fella is not helping?? (old farts working----kids with hands in pockets----just like my house )
| body and floor welded to frame...hmmm? | atotalnincompoop | Hotrodding Basics | 4 | 03-10-2008 07:57 AM |
| body change to later frame | streetrod936 | Suspension - Brakes - Steering | 11 | 12-15-2005 07:44 AM |
| body frame | roczilla | Introduce Yourself | 2 | 12-12-2005 09:22 PM |
| removing body from frame | trident | Body - Exterior | 8 | 05-11-2005 04:01 PM |
| Body & Frame question | ruiner808 | General Rodding Tech | 7 | 09-14-2003 05:54 AM |
