removing body trim? how? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2009, 11:15 AM
An advice on removing the plastic lower body trim on 1990's GMC SLE pickup. I will be painting it all black, and do not want to reinstall the trim. I don't know for sure but I think it is glued on somehow. Will a heat gun loosen it up...just pry it off... is it held on mechanically? If so ... weld any holes up with a mig? thanks
Old 03-31-2009, 04:18 PM
willys36@aol.com's Avatar
Wiki Edits: 21
They did a piece on this on last week's "Trucks!" (or maybe it was Hot Rod - they were reclaiming a totaled late model pickup - body damage, rest of truck was in great shape - and took off some trim instead of replacing it $$$) TV show. Modern trim is glued on, no mechanical fasteners. They peeled the trim off with the help of a plastic Bondo spreader. Then they 'polished' off the residual glue using a rubber 'eraser' wheel in an electric drill. Came out perfect w/ no paint damage.
Old 03-31-2009, 04:31 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
willys, I'd like to see them try that with a rust belt truck. Anything over about 10-15 years old, and the spreader might go all the way through. Of course, there would have to be some paint left on the truck for that to happen...
In a while, Chet.
Old 03-31-2009, 05:30 PM
Wiki Edits: 21
Can't relate. Have always lived in the People's Republik of Kalifornia.
Protecting screw holes or trim holes in body? ScotY Body - Exterior 6 01-29-2009 02:37 PM
Removing trim around windows daanp Body - Exterior 9 03-22-2008 07:00 AM
Removing the body Rufus_2 Body - Exterior 3 11-14-2006 08:08 PM
Hotrodders Knowledge Base: Body - Exterior Jon Body - Exterior 0 11-26-2005 07:33 PM
Removing Windshield Trim Juans55Olds Body - Exterior 1 09-18-2003 11:07 PM
