Removing brake fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2009, 03:22 PM
I sandblasted the floor of my car to get it ready for epoxy primer. My master cylinder just started leaking and now the bare steel has DOT3 brake fluid on it. Is there any special way to remove the brake fluid before I paint? Do you just clean everything with Brake cleaner? Will waterborne wax and grease remover clean it?
Old 04-07-2009, 04:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have heard of people using phoshpuric acid before but i havent used it myself.i would get some kind of degreaser then i would scotchbrite it with red scotchbrite i have done this to clean bare sheet metal before and it does work.but i am sure someone on here will have a better way if they do they will tell you.hope this helps. cole
Old 04-08-2009, 06:34 AM
I would use brake cleaner and then go back over it with wax and grease remover. Ive accidentally spilled fluid on brake pads already shot it with brake cleaner and all was fine.
Old 04-08-2009, 07:35 AM
302 Z28's Avatar
It wouldn't hurt to saturate the area first with acetone, but wear protective gloves and a mask.
Vince
Old 04-08-2009, 07:38 PM
Cape Cod Bob's Avatar
Fix the leak first cause it may take the paint off.
Old 04-09-2009, 04:48 PM
I thought water would neutralize brake fluid.
Best way to flush brake fluid intergalactica Suspension - Brakes - Steering 7 12-24-2008 12:30 AM
Where's my brake fluid going?? STATUTORY GRAPE Suspension - Brakes - Steering 7 05-22-2008 06:24 PM
Removing emergency brake parts jpd37 Suspension - Brakes - Steering 1 07-10-2006 07:39 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Brake fluid gottaluvchevelles Suspension - Brakes - Steering 5 11-13-2004 05:39 PM
