please post pics as you go, I've got a set of wheels needing the same thing...once my truck is driveable
thanks, James p.s. got any pics of the wheels in present condition? |
CMA makes the best stripper out there. You put it on let it dry and your done no big mess. Almost all the MAACOS use it. The product makes aircraft stripper look silly
200, what does CMA stand for?
thanks |
i am not sure what it stands for the company just makes strippers,some clears, and a few other items even a nice spray mask. They use to do alot for Mar-hyde i think before the started to make there own products. I will try to find there website and post its nothing fancy
think there website is www.cmaproducts.com only items i have used is the stripper and fast dry clear both worked well Last edited by 200horse; 03-01-2010 at 07:26 AM. |
The key to getting the most out of chemical stripper is to not let it dry out. If you can some how coat the surface area of the rims and seal them in a plastic bag overnight the stripper may work better. FWIW, do not fall for the "Aircraft Stripper" hype. A while ago I posted links to two MSD sheets, one for regular stripper and one for aircraft stripper from the same manufacturer. The ingredients and proportions on both were identical.
Vince |
the CMA strip it dry is made to dry out so you do not have a mess great product people just do not know about. the guys at CMA says its better than there aircraft type stripper real air craft strippers have some properties required on aircrafts from my understanding |
agree with vince,,,cover it while still wet...
put a dab of your brand stripper on a piece of a polyethylene trash bag and/or a piece of saran wrap (pvdc) to know the stripper does not react with the plastic... no reaction just lay the plastic to be tight on top of the wet stripper... lol,,,think of it as marinating some meat,,,it takes time to work it's way in... wheel coatings gotta' be extremely tough to stand up to stones and brakes heat... ergo,,,they are a challange to remove... |
Good ideas. I'll try the plastic cover trick with both Kleen Strip and Mar-Hyde and see what works best. Keeping them wet overnight should be more effective. Wonder why the manufacturers didn't think of that. Haven't seen the Mar-Hyde instructions yet but Kleen Strip just suggested using the plastic brush to help things along. Didn't work.
just my $.02:
Kleen Strip is better suited for removing "air dry" cure coatings like enamels and acrylics... the coating on the wheels is very likely a 2 part catalytic reaction material... (could be urathane/poly urathane/acrylic urathane or epoxy base) I've not used it for stripping wheels coating,,, but Jasco brand "Premium Paint and Epoxy Stripper" does do darn well for lifting 2 part epoxies... (Lowes/$9?) "if" the Kleen Strip soak won't lift it after a couple of days and applications... Hwy,,,lol,,,no I don't sell the stuff,,,have used 10-20 brands over the years on many different applications and the Jasco is by far the best for the money on anything... Last edited by red65mustang; 03-01-2010 at 09:40 AM. |
200horse,
I read the TDS on the CMA site... the Jasco does work the exact same as the CMA stripper,,,"pops" the paint up and goes totally dry so you can just brush/blow/lift the old paint off in sheets... That's why I do like the Jasco so much (no mess),,,plus Jasco is a thick/almost gel that clings excellent so no need to do a bunch of tape and paper... is the CMA thick or thin consistancy???? |
jsa,
first post says you kept brushing the stripper... not good,,, you want to blob it on and only work with a brush to level it like you were frosting a cake then leave it alone... also do it in a shady spot,,,not in direct sunlight |
| Flames without the clear coat?? Yes or No | Jim Weeks | Body - Exterior | 4 | 04-13-2009 05:21 PM |
| Base coat clear coat repair problem | TimeBandit | Body - Exterior | 2 | 09-03-2008 06:22 PM |
| Clear Coat | RaeMR2 | Body - Exterior | 1 | 01-22-2008 05:00 AM |
| Clear Coat Problems Help!!! | coupe33 | Body - Exterior | 4 | 01-01-2008 07:55 AM |
| Base Coat / Clear Coat Qusetions | JOEPATRICK2 | Body - Exterior | 17 | 11-23-2007 01:38 PM |
