Removing clear coat off Light Frames. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2013, 02:37 PM
I am in the process of buffing out the trim on my P/U/. There is a Clear Coat on the Light Frames. I would like to remove this clear coat. Does anyone have an idea on how to do that. I have sanded but it takes much to long to accomplish it by using this method. Any assistance will be appreciated. Thanks.
Old 04-12-2013, 02:53 PM
Faith - Respect - Trust
If this is original clear from 1963 it should be a lacquer clear, which would tell me that lacquer thinner would wash it off quite easily, if it's a 2K clear that somebody applied after to keep the stainless shiny, which I wouldn't understand why somebody would do that but regardless, if you have Carb cleaner, or even brake fluid, Aircraft paint stripper any of those would work...the brake fluid or carb cleaner would take a little longer but you may have that hanging around. Aircraft stripper would take it off in minutes, it's fairly caustic so don't do it at the kitchen table, take it to a well vented area, like the bedroom or turn the fan on in the bathroom, (just kidding)...LOL...some guys even take it out to the garage and have the door open. What are you using to buff the stainless when you have the clear coat taken off?
Oh, by the way, they kinda like if you have any specific questions, to put them in the specific category...this one would be under paint and body but hey, it's your first day and not that big a deal.
Hope this helps.
Ray
Old 04-12-2013, 05:05 PM
So, here we are in the body and exterior section...kinda thought we would be.
Ray
design ,stripes, wich paint base coat over spi clear coat Vincentnova Body - Exterior 1 08-12-2012 09:19 PM
spraying clear coat on top of clear coat? bennecc Body - Exterior 9 05-08-2012 05:59 AM
Clear Base coat vs Clear Top coat waterdude Body - Exterior 7 12-13-2010 12:11 PM
removing runs in clear coat??? 350cruiser Body - Exterior 16 10-17-2010 07:52 PM
Removing Clear Coat from Aluminum jsarnold Body - Exterior 18 03-01-2010 03:54 PM
