Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 09-04-2005, 11:16 AM
84Z 84Z is offline
Gas Raper
Removing dents in headers?
Is there anyway to remove dents in the primary tubes of headers? I'd rather not cut the chunk out and reweld. Is there any other way?
  #2
Old 09-04-2005, 11:39 AM
56Maynard 56Maynard is offline
You might be able to pop it out with a morgan knocker. But you'll still have to weld up the hole. Whats wrong with cutting and pasting?
Old 09-04-2005, 11:42 AM
84Z 84Z is offline
Gas Raper
My welder broke . Can I cant afford a new one yet. I'll check otu these knockers, thanks.
Old 09-04-2005, 12:04 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
Might have to heat the area around the dent if they are the thich wall headers...? Have done this before with a reg slide hammer type puller and just rewelded the holes with the torch too... (grinder can dress them back up)
If they are ceramic coated headers then you have to buff off a small area to weld up the hole... Also have to use something to touch them up...
Old 09-04-2005, 12:10 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Don't drill holes you will have a mess...., use the body dent puller that welds a "nail" on the metal, work from the outside in, heat around the dent gently, pull the dent out, and grind off the nail, just like body work...
Old 09-04-2005, 03:55 PM
73oldsman's Avatar
73oldsman 73oldsman is offline
Try going to a fix-a-dent place if there is one in your area. They have all the tools to get in tight places. Info here; http://www.pdqtools.com/?src=overture. Maybe they can help!
Old 09-04-2005, 03:59 PM
Bumpstick's Avatar
Hammer and a torch
xntrik... Yes a better idea but he`s trying to do this cheap...
84Z... You can get what xntrik was talking about but the cost may be more than you want unless you can use the tool in the future... (my moto is never sell a tool...)
Old 09-04-2005, 04:43 PM
jesse01's Avatar
jesse01 jesse01 is offline
mini me
do like they do to tpi runners. get a like a ball bearing that just fits inside the hole and get something to push it through. it'll pop that little dent right out
J
Old 09-04-2005, 04:47 PM
xntrik's Avatar
J
Good Idea.... but what if it gets stuck and you cant push it back from the other side......
Old 09-04-2005, 04:49 PM
xntrik's Avatar
find somebody to help that has a stinger tool.......
Old 09-04-2005, 05:37 PM
steve t's Avatar
steve t steve t is offline
ex biker, now hotrodder
J
that would have to be a mighty big ball bearing
Old 09-04-2005, 05:54 PM
84Z 84Z is offline
Gas Raper
If I do get a stud welder and use the puller, do you think I can pull the dent out? Even if the header is heated it's still pretty thick metal...
Old 09-04-2005, 06:05 PM
spinn's Avatar
spinn spinn is offline
Tried true
ya, soften it with heat and hope for the best.
xntrik's Avatar
Yep, been there, done that. Just remember, work from the outside toward the center in circles, just like doing a body dent.
Find somebody with a nail welder/puller, and buy a bag of "nails" and have him help ya.
Old 09-04-2005, 06:45 PM
coldknock's Avatar
coldknock coldknock is offline
I wanna know where you found headers that don't need to be dented in order to fit right!
Larry
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Removing dents in headers?"
ThreadThread StarterForumRepliesLast Post
Ceramic Coated Headersmike bryanEngine1509-02-2010 05:47 PM
Can't find headers for my 2002 GMC SierraMad MaggotEngine1109-17-2008 09:19 PM
Headers are done78 monteEngine1009-04-2004 03:52 AM
tri y headers or standard full tube headersfordracingEngine1006-13-2003 07:39 AM
What has been your experience with headers compaired to stock exhaust manifolds??Jim WeeksEngine705-14-2002 06:56 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
