Removing die from interior panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 11:49 AM
So the previous owner quit 10% of the way through redying the interior on my 68 Cougar black. So I'm left with two panels that were originally dark green but are now black. The panels are in fine shape so I'd like to remove the dye without harming the original vinyl's colour and grain.
I've tried acetone on a portion of the panel that is unseen when they are installed and it took some off, but it took a huge amount of acetone in comparison to how much came off and I'm not sure I could do much more without some kind of respirator.
Any suggestions on how to get the dye off?
Old 02-11-2006, 11:49 AM
fairlaneranch's Avatar
New Member
Last journal entry: my new toy
try castrol superclean FULL STRENGTH! I use it to strip paint off of model cars and it works great !You will have to keep it wet for A little bit but it will not harm the vinyl at all.Try it,And if it dont work you have degreaser that works great so its a no lose deal
Air Tool die grinder. Which one to get? fourbyfourblazer Garage - Tools 9 12-13-2004 08:11 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Engine wants to die from park to drive Siggy_Freud Engine 4 06-03-2004 11:21 PM
removing camaro engine by removing sub-frame bullheimer General Rodding Tech 7 04-23-2004 02:46 PM
need help, removing ac system on 91 mustng jfmustang General Rodding Tech 1 04-19-2003 04:20 AM
