Removing drip rail chrome? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2009, 04:15 PM
Trucknut's Avatar
What's the best way to remove the chrome from the drip rails on a 1966 LeMans?
Old 04-17-2009, 06:25 PM
Old Fool's Avatar
Best method I have found is to use a heat gun. Warm it up good and gently roll it off of the rail. Grip the trim on the top and bottom edge then apply constant light pressure in a twisting motion.
Wear gloves cuz its going to be hot.
Dont heat it so much you discolor your trim.
Old 04-18-2009, 06:31 AM
I herd one time that amonia removes crome I have never done it though. What does heat do that you can remove the crome by peeling it?
Old 04-18-2009, 08:08 AM
Trucknut's Avatar
Thanks OldFool. I'll give it a try. I think the idea of heat is to soften any adhesives that may be under the chrome. The concern is taking then of without bending them, installing a new vinyl top after painting, polishing them and putting them back on. I may have ask the question wrong. I don't want to remove the plating. I want to remove the trim.
I appreciate your help guys.
Chris
Old 04-19-2009, 12:44 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Try an old style bottle opener with friction tape around the end to prevent scratches, just be gentle.
Semper Fi
Old 04-19-2009, 06:23 AM
Trucknut's Avatar
The bottle opener seems to be the answer. I read the same on a couple of other forums. Thanks for the help
Chris
Installing Stainless Steal Drip Rail Trim 65comet Body - Exterior 0 10-28-2008 08:52 PM
Drip Rail w/ new quarter crusherdbuzz Body - Exterior 1 06-13-2008 10:08 PM
Drip Rail Delete SHIFTY101EASY Body - Exterior 27 01-30-2007 03:24 AM
How to prepare drip rail channel Donnie W Body - Exterior 2 08-02-2006 10:10 PM
Drip rail help 46 chevy pickup Body - Exterior 2 06-12-2006 05:12 AM
