Removing emergency brake parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2006, 08:33 AM
I know disabling the emergency brake is not a good idea. But in my case it is not hooked up anyway. I have plans to do the installation this winter. In the meantime, I have been living with these loose cables coming out of the rear backing plates and the rattling is driving me nuts. So I want to remove the cables. If I do, should I also remove the lever inside the brake assembly or can it stay in there? I don't want to have loose parts flying around in there you know. Something bad might happen. Thanks for your advice.
Old 07-10-2006, 07:39 AM
On dirt track cars ... I have cut the cables right at the backing plate ... without problems but I encourage you to go ahead and fix the cables correctly and hook everything up ... for safety sakes ...
Deuce
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 08:20 AM
2.3L parts cant seem to find any performance parts for it JustinHebel Engine 3 02-25-2006 11:49 PM
Emergency brake cable que. 39chevy Suspension - Brakes - Steering 3 10-19-2004 08:24 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
