Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing emmission control components
Old 01-08-2011, 10:54 AM
LATECH's Avatar
LATECH LATECH is online now
Also a 1990 ford had an AOD not a c-4. If it has a lockup converter operated by the ecm and not just by hydraulic then you will need the BOO switch.Otherwise it shouldnt pose any issue. (Brake On Off)
