Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing emmission control components
Old 01-08-2011, 07:07 PM
LATECH's Avatar
LATECH LATECH is online now
Originally Posted by DanielC
The Thermactor is the air pump, fresh air into the exhaust system,
EGR is exhaust gas recirculation.
They are pretty independent of each other, but keep in mind, everything on modern engines is interrelated.
The air pump pumps fresh air into the exhaust, and it helps burn off unburnt hydrocarbons
and convert CO to CO2, in the catalytic converter.
EGR is used mainly to reduce oxides of nitrogen, from the engine. It can also be used in some conditions to reduce spark knock.
Dan C got a 100 on this one.Exactly perfect. I also like his suggestion to keep the evap functional,especially if you garage park your car.You wont smell fuel in the garage if it is working properly. Kudos Dan C
