-   -   Removing Etching Primer (http://www.hotrodders.com/forum/removing-etching-primer-230060.html)
James670X 02-26-2013 07:02 PM
16 Attachment(s)
Is there a chemical out there a guy can use to remove this stuff?... Don't really want to grind it off...
OneMoreTime 02-26-2013 07:19 PM
Paint stripper will do it..Tip is to lay plastic sheeting over what you have applied to keep the stripper moist and let it work for you..
Sam
James670X 02-26-2013 09:58 PM
16 Attachment(s)
Is there a cheaper way than using paint stripper? Like thinner?
OneMoreTime 02-27-2013 01:55 AM
I am not aware of anything cheap and easy about doing this..If it is easy it is not cheap and if it is cheap it is not easy..
Sam
swvalcon 02-27-2013 06:56 AM
What is the primer on and what are you tring to do?
69 widetrack 02-27-2013 10:52 AM
swvalcon has a good point...if it's an A & B type etching primer it will either wash off with thinner or it can be sanded off...so if you know what kind it its, that would help. Did you apply the Etch primer or was it on the car when you got it?
Ray
mitmaks 02-27-2013 07:46 PM
Try some acetone on a rag.
deadbodyman 03-03-2013 05:41 AM
or ,it should sand right off with 180 DA also
James670X 03-05-2013 06:45 PM
16 Attachment(s)
http://sphotos-e.ak.fbcdn.net/hphoto...98649716_o.jpg
James670X 03-05-2013 07:47 PM
16 Attachment(s)
http://www.facebook.com/james.s.3760?ref=tn_tnmn
James670X 03-05-2013 10:03 PM
16 Attachment(s)
This is the primer I used
deadbodyman 03-06-2013 04:38 AM
That'll wash right off with lacquer thinner....:thumbup:
69 widetrack 03-06-2013 12:00 PM
Or if you give it a dirty look it'll probably fall off. Mike is right, it'll wash off with thinner...good call to take it off...what are you putting on in it's place.
Ray
James670X 03-06-2013 01:43 PM
16 Attachment(s)
Ray
I'm going to re-spray it in Epoxy
69 widetrack 03-06-2013 01:48 PM
Good call, the rattle can etch does have it's place, (small burn through's etc.) but not on large surfaces and overall protection as a full blown project like yours.
Good luck James.
Ray
