Paint stripper will do it..Tip is to lay plastic sheeting over what you have applied to keep the stripper moist and let it work for you..
Sam
I am not aware of anything cheap and easy about doing this..If it is easy it is not cheap and if it is cheap it is not easy..
Sam
What is the primer on and what are you tring to do?
Try some acetone on a rag.
or ,it should sand right off with 180 DA also
That'll wash right off with lacquer thinner....
Or if you give it a dirty look it'll probably fall off. Mike is right, it'll wash off with thinner...good call to take it off...what are you putting on in it's place.
Ray |
Good call, the rattle can etch does have it's place, (small burn through's etc.) but not on large surfaces and overall protection as a full blown project like yours.
Good luck James. Ray |
| Epoxy Primer or Etching Primer ? ? ? | SCHOONER | Hotrodding Basics | 3 | 03-01-2010 07:18 AM |
| Self Etching primer vs. epoxy primer | elcaminodragster | Body - Exterior | 47 | 06-08-2009 07:17 PM |
| can i spray epoxy primer over etching primer without sanding? | wickiewicked240z | Body - Exterior | 1 | 08-29-2006 09:07 PM |
| Epoxy Primer / Etching Primer | olds37dude | Body - Exterior | 3 | 01-27-2005 04:25 PM |
| Do you need etching primer under featherfill primer? | Fordy8man | Body - Exterior | 14 | 10-29-2003 07:23 PM |
