Removing Glass from a Vent window - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2005, 10:22 PM
Roadsire's Avatar
Last journal entry: Dash mods
I have a 54 chevy truck and am trying to figure an easy way to remove the vent glass from the frame anyone know a trick to aid in its removal?
Old 07-21-2005, 11:18 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Good thing you asked, I need to do the same on my '50 Dodge to replace the weatherstripping but have no idea how to
Mike
Old 07-21-2005, 11:26 PM
Muncie's Avatar
New Member
The way I always did them at the glass shop I worked at was to lay the flat on a bench, take a nylon block, we used uhmw, Lay it almost flat on the glass and start to gently tap the frame off all along the glass. I will take alittle bit to get the frame off as the gasket has a gripping surface that grabs the glass on most of them.
Old 07-22-2005, 06:20 AM
IROC100's Avatar
Running on empty
Last journal entry: More pics
What I did to get my glass out was to spray some WD40 or PB Blaster on it and let it set for a day and then just keep working it like Muncie said or just hold the frame and pull the glass. Try to get the top corner out first and spary more blaster behind it. You'll be surprised how much rust is in there. Good luck.
Old 07-22-2005, 06:40 AM
Roadsire's Avatar
Better Living through chemistry
I thought that a petroleum product would be in play, I may try soaking it in a vat of "snake oil" kerosene or the like for a while and then coaxes it out the frame.
Thanks for the tip..................
window install Jzarczyn Body - Exterior 10 01-24-2009 11:02 PM
Window channels and removing vent window Jackyl Interior 11 10-10-2007 07:01 AM
Basic of Basics - Windshield Installation Kits firebird_red Body - Exterior 15 11-26-2005 09:00 PM
Removing vent window on '58? Nanook Body - Exterior 3 01-09-2005 06:06 PM
door glass fred56 Interior 4 10-22-2003 09:40 PM
