EMAIL PROTOCOL SAYS I SHOULDNT WRITE IN CAPS BECAUSE IT'S LIKE YELLING, WELL, MY EYES ARE HARD OF HEARING. IF YOU HAVE AN AIR COMPRESSOR, OR ACCESS TO, GO TO HARBOR FREIGHT OR SOME SUCH STORE AND BUY A SMALL SAND BLASTING SETUP.($20-30) ,.CLEAN SAND IS ONLY $2 A BAG. THEN BLOW AND FINALLY VACUUM CLEAN. THE SMALL GUN ALLOWS RELATIVELY PRECISION WORK, AND YOU WILL FIND A ZILLION USES FOR IT AFTER, LIKE CLEANING TONS OF THINGS. I ONCE RENTED A COMMERCIAL TRAILER MOUNTED COMPRESSOR AND BLASTING TANK AND CLEANED TO BARE METAL MY ENTIRE '50 GMC FRAME AND ALL. (COMPLETELY DISASSEMBLED). THERE ARE DIFFERENT GRITS OF SAND AVAILABLE, BUT FOR YOUR PARTICULAR TASK, JUST GO TO THE LUMBER STORE/YARD AND BUY CLEAN SANDBOX SAND.
