Hotrodders Bulletin Board
#1
Removing lifter bore rust.
I've recently been given a 350, thats well, sat for a while. And i can't even remove the lifters out of it. So i've currently got it soaking in oil, praying that their isn't any rust in the lifter bores, but more than likely their is. So is there a way to hone the rust out as long as the bores aren't potted to badly. Or would it just ruin the block altogether.
#2
I would do some close micing of the bore afterwards and compare to a new lifter. SBC are notorious for dumping oil out the lifter bores anyway, so a little more might be too much. Oversize lifters are available. |
#3
cool, glad that there is still some hope for this motor. I'm on my third 350 block so far. History 1st: crack in two cylinders and outer block 2nd: extreme overheating. Lets just pray the third doesn't go down from a little iron oxide.
#4
I would say get it acid dipped. Acid dipping will remove all rust including that trash inside the water coolant passages. It only costs a few bucks, IF your local shop has an acid tank.. You scrub every oil passage and everything 3-4 times with good hot soapy water to make sure all the crud is gone..... even after acid dipping. |
Back to top |
Similar Threads for: "Removing lifter bore rust."
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| rust removing and coating | TheCiscoKid | Hotrodding Basics | 3 | 12-18-2005 02:21 PM |
| big block chevy "tall" lifter bore | BBCMudbogger | Engine | 3 | 12-07-2005 08:19 AM |
| Rust Dissolver versus Rust Convertor? | 66GMC | Body - Exterior | 9 | 11-06-2005 05:48 PM |
| how to prepare a block | blndweasel | Engine | 14 | 08-15-2003 12:28 PM |
