Removing Lower Control Arm Shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2006, 08:04 AM
Can anyone tell me how to remove the bolt, (shaft) from the rear, lower control arm on a 1963 Chevy Impala. This bolt connects lower control arm to rear end and is also mounting bolt for shock.
I have the nut off, the front control arm bolt removed but cannot budge the shaft an iota. Is it pressed in, spot welded or just plain froze in place?
Thank you in advance
4th Control ARm????????? Toni Pepperoni Suspension - Brakes - Steering 7 09-23-2005 09:49 PM
Nova Lower Control Arms Pro1972nova Suspension - Brakes - Steering 1 12-15-2002 02:26 PM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 04:19 PM
Lower control arm bushings. What are the tricks of the trade?? Jim Weeks Suspension - Brakes - Steering 7 05-11-2002 09:08 PM
rear lower control arms oldsnut Suspension - Brakes - Steering 3 12-15-2001 10:01 AM
