Removing moisture in air to media blaster - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2010, 07:57 PM
I have a moisture trap coming out of the compressor tank (80 gallon Black Max) and one going into the Harbor Freight 40 Lb. Pressurized Abrasive Blaster. How often should I release the moisture? The moisture traps are opaque, so it's hard to tell when there is a significant amount in them. I also have the drain on the bottom of the compressor tank.
TIA
Chaz
Old 02-23-2010, 08:23 PM
life is a temporary assignment
I like to crack open The drain before each time I use it.. It is a very good habit to get use too..
Old 02-23-2010, 09:27 PM
i've had the same problem. I took the cap of the blaster, put a diesel heater next to it overnight. It drove the moisture out and it worked great after that.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 02:01 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
removing air conditioning F85 General Rodding Tech 1 07-27-2003 12:14 AM
Air released when removing gas cap? HotRodMan Engine 1 01-30-2003 08:13 PM
