Removing a Must. II crossmember for a 38 chev. frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2006, 08:37 AM
Hi, I recently bought a 38 chev. sedan with a stock must. II crossmember welded to the frame. I also discoverd that the upper A arm is 1/2 inch fwd than where it needs to be, is cutting it out and redoing it with a after market unit the best way to go, I'm afraid if I leave it in the wheels will not center right. Any suggestions will be appreciated. Also if I cut it out will may frame need exstensive work? Thanks Guys
Old 01-14-2006, 08:41 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome aboard! Glad to have you with us. You really ought to post your question in the Suspension forum...this forum is for introductions. Thanks.
Old 01-14-2006, 02:02 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
WELCOME TO HOTRODDERS.COM
"SlowRide66"
"Illegitimis non carborundum"
Old 01-14-2006, 02:34 PM
poncho62's Avatar
Wiki Edits: 5
moving to suspension forum.
Old 01-14-2006, 06:28 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
mustang II crossmember
I have installed M-II front ends in 3 old chevys, 1in a 38 and 2 in 39 s I moved the centerline of the spindles ahead 3/4 inch from the stock suspension center, to center the wheels in the fenders. with a lowered stance and small diameter wheels and tires the wheels will appear to sit back in the fender opening if you mount the suspension in the stock location. I am not real clear if you mean one upper arm is ahead or both arms are ahead.
Old 01-14-2006, 07:29 PM
Hi, Thanks for the info, the upper A arm and the hole in the frame that suppose to be the center line of the axle is 1/2 in fwd, from what you said I might be in the right position. Thanks
Old 01-15-2006, 06:21 AM
Thanks to Henry Highrise
Big Thanks, I'm new to this website, so thanks for directing me to different area of knowledge. Thanks Ylchild
Chevy II Swap - Frame Mounts, Etc... Delirious2000 Engine 6 03-29-2004 03:06 PM
49 chev on chevelle frame? roadweasel Suspension - Brakes - Steering 4 01-29-2004 05:35 AM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
frame crossmember johnnymopar Suspension - Brakes - Steering 7 05-29-2003 04:04 PM
9" ford in 48 chev frame fat48chev Body - Exterior 7 06-30-2002 08:37 AM
