removing my drip rails. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2006, 08:34 PM
Hello, I'm working on a 1965 Mustang Coupe and I want to cut off the drip rails. Can anyone help? I'm looking for the best way to do it, also if anyone has pictures of there mustang with drip rails removed I would like to see them. Thanks for your help.
Justin
Old 07-23-2006, 09:24 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I have never done this but I have heard it is very tricky. They cut off a lil bit at a time and then weld that area or else the roof skin may warp and lose its shape.
Old 07-24-2006, 01:14 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
he hit it on the head.....
I cut as close as i could with a sawzall, then used my angle grinder to take 4-5 inches at a time down as close as i wanted, skipped a few or five inches, all around the roof line.. migged in what i'd ground, then went back and ground what i'd left behind. then migged that up. weld it all up, skip around as not to cause warpage with the welding heat. then use a flapper disk to smooth it out. go back and weld whatever you grind through... weld grind weld grind till you get that like you want....
then if your not to proud, throw some evercoat on it and get that right.... filler sand filler sand filler sand til you get that like you want....... then primer and paint that bad boy....
Old 07-24-2006, 07:26 AM
drip rail removal
i removed the drip rails on my 68 mustang gt fastback. i used brake lines , cleaned out the drip channels, ground using cut off tool, clamped lines down into channel, weld top of lines to roof, then cut underside of drip rail off, removed drip rail, weld bottom side, did a lot of wire brushing and grinding, filled in with napa fiber strand, turned out great. sorry don't have pictures. but by using the existing drip rails as a guide, it did a great job, hope this info helps you.
Shaving Drip Rails B-DOGG0918 Body - Exterior 12 09-29-2005 09:26 PM
Drip rails alronz Body - Exterior 8 02-10-2005 11:03 PM
drip rails Jzarczyn Body - Exterior 6 02-05-2004 05:44 PM
Can shaving Drip rails be a disadvantage? garreett0 Body - Exterior 1 09-05-2003 04:52 PM
32 ford drip rails andy223 Body - Exterior 2 04-21-2002 05:24 PM
