Removing my windshield. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2006, 09:04 PM
Everything is HAMMER!
I did a search and it said i need a window knife, a trim molding tool, a warm day(heated shop), and some piano wire. What are the steps included in doing this. Would a guitar string work instead of piano wire. BTW this is in an 84 camaro. Thanks for the help.
Old 01-12-2006, 05:21 AM
302 Z28's Avatar
A guitar string will probably work, but you need a wire that is smooth to make it as easy as possible to cut through the butyl rubber adhesive.
Vince
Old 01-12-2006, 06:08 AM
milo's Avatar
point on positive
I was gonna say to look around for a new glass in case this one breaks first..Ya never know it can happen... Best have a plan B in case...
I'm a diy fan of almost everything except glass . It can be one of the things left to someone who does it everyday.
There is a tool that has a handle on the end of a cable that pulls a right angle blade through the glue .
split windshield center seam powerrodsmike Body - Exterior 6 11-03-2005 10:37 PM
Removing windshield seal cement? Gearhead forever Body - Exterior 4 10-30-2005 07:55 AM
Cutting curved windshield swoodard23 Body - Exterior 16 08-05-2005 10:27 AM
Removing windshield? 87442lover Body - Exterior 5 04-01-2004 11:03 AM
Removing Windshield Trim Juans55Olds Body - Exterior 1 09-18-2003 10:07 PM
