Removing old bondo - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2005, 08:45 PM
Removing old bondo
I have a modified 50 Hudson that has bondo on the door panel that is cracked and needs to removed. I have had two suggestions on how to remove the bondo. One was to use heat from a propane torch to gentle heat and scrape off the old filler. They stated to be careful and not get the door real hot as it will cause a warping problem. The other suggestion was to grind out the old bondo.
Would appreciate you suggestions on what would be the best way to remove the old bondo.
Old 12-21-2005, 08:48 PM
tbirdscott's Avatar
stuff'n things'n whatnot
I always use a knotted wire wheel on an angle grinder, just be sure to keep the heat down and wear a respirator
Which bondo should I use? Nightfire Body - Exterior 8 07-26-2004 05:38 PM
Bondo vs Dynatron ChrisMiddleron Body - Exterior 10 08-29-2003 04:07 AM
o Bondo or not to Bondo? snnokmaster Body - Exterior 5 08-22-2003 07:56 PM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 08:02 PM
bondo removal question broncoman Body - Exterior 3 06-22-2003 01:16 AM
