Removing old bondo - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2005, 08:47 PM
Removing old bondo
I have a modified 50 Hudson that has bondo on a door panel that is cracked and needs to removed. I have had two suggestions on how to remove the bondo. One was to use heat from a propane torch to gentle heat and scrape off the old filler. They stated to be careful and not get the door real hot as it will cause a warping problem. The other suggestion was to grind out the old bondo.
Would appreciate you suggestions on what would be the best way to remove the old bondo.
Old 12-21-2005, 08:50 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Wear a good resiprator and grind it out with some 36 grit..should not take all that long...That torch idea does not sound all that good to me..
OMT
Old 12-21-2005, 08:53 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
OMT
a wire wheel will do a nice job and not generate too much heat.
Old 12-22-2005, 06:42 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
the propane torch works great. you don't heat the bondo. one pass over it and it will turn to dust. i use a welders brush to remove it. fast and a lot cleaner than grinding. the torch pulls the solvent out and leaves it dry and brittle. give it a try.
Old 12-22-2005, 06:59 AM
Wiki Edits: 3
Heavens, learned something else today..
OMT
Old 12-23-2005, 12:16 AM
A muffler gun with a blunt chisel, turn the air pressure down a little, it will take it off fast with out denting it if you take it easy.
Rob
"There are questions to be answered, and answers to be questioned"
Chassis, Body Jig, Trunk Pan Pics.
http://webpages.charter.net/2manitowoc
Paint booth, Ventilation, etc.
http://www.2manitowoc.com/paintroom.html
Removing old bondo arionrjw Body - Exterior 1 12-21-2005 08:48 PM
Which bondo should I use? Nightfire Body - Exterior 8 07-26-2004 05:38 PM
Bondo vs Dynatron ChrisMiddleron Body - Exterior 10 08-29-2003 04:07 AM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 08:02 PM
bondo removal question broncoman Body - Exterior 3 06-22-2003 01:16 AM
