-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Removing old carpert and its adhesive (http://www.hotrodders.com/forum/removing-old-carpert-its-adhesive-230489.html)
krunch007 03-09-2013 03:39 PM
Hey guys,
Looking for any tips to remove the former carpet adhesive that is in my 1970 C10. I am updating the interior and would like to put a Dyna Mat type of product in. But the old carpert that was in the truck had spray on adhesive holding the padding down. Now it just all furry. I have been picking away at it but there has t be a better way. Any advice is appreciated.
killeratrod 03-09-2013 04:38 PM
try a product called goof off. let it soak and you will be able to use a putty knife to scrape it off , let it fully dry , then wipe it down /and dry again. Then do the new . Get it at home depot.
DanTwoLakes 03-10-2013 07:41 AM
If it's a contact adhesive, the solvent for it is mineral spirits or Xylol. There's also a product called Oops! that says it can remove glue. Mineral spirits will be far less expensive.
