Removing old insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2013, 12:30 PM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Anybody got any suggestions on removing old insulation from inside of my 39? The exterior of the insulation comes off pretty easy, but leaves behind a sticky mess.
Thanks
Name:	old insulation.jpg
Old 05-22-2013, 01:59 PM
Banned
this will clean it up!
Name:	goof off spray.jpg
Old 05-22-2013, 02:01 PM
DanTwoLakes's Avatar
Wiki Edits: 22
That's probably asphalt of some kind, and it won't come off easily. You are taking it out for what reason? It's been there for 74 years. I assume you want to put Dynamat or something like it up there. Just add whatever you're adding right over the top. I'd clean it up with some mineral spirits first.
Old 05-22-2013, 06:29 PM
Trophyman's Avatar
Yea--I tried that as well as Acetone & Lacquer Thinner. MEK (methyl ethyl ketone) cut it but I really donít want to work with the stuff overhead inside the car.
I, also, thought that I would just leave it and put the Dynamat over it but wasnít sure. I donít need any problems once I get the upholstery done. I suppose that since itís been up there for 74 years, (and it really is stuck!) Iíll just go over top.
Thanks
Old 05-22-2013, 08:39 PM
Wiki Edits: 22
As a professional upholsterer I can tell you that covering it up will be just fine. Just leave yourself a good solid surface to apply the Dynamat to. If you're going to use the original bows for the headliner you don't want the roof to be too thick or it can get in the way of the bows and headliner.
insulation flatblack16 Interior 10 07-22-2009 04:03 PM
insulation old40ford Body - Exterior 1 01-11-2007 12:30 PM
Insulation Charles F. Smith Hotrodders' Lounge 4 11-20-2004 11:19 AM
removing camaro engine by removing sub-frame bullheimer General Rodding Tech 7 04-23-2004 03:46 PM
insulation huffed6 Interior 4 08-13-2002 02:59 PM
