Removing oxidation from Aluminum wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 08:01 AM
I recently purchased some slot wheels that are brushed aluminum. There is some oxidation marks on the rims. What can I use to remove this and clean them up? The wheels are not high shine I do not think.
Old 06-03-2011, 09:08 AM
Steel wool and lots of elbow grease.
Old 06-03-2011, 01:55 PM
If they have a clear coat on them, use a fine drywall sanding screen and do it dry while wearing a dust mask. Then start with 600 grit and work your way up to a mirror finish say 600, 800 then 1200. Then buff with aluminum polish and a pow-r-ball thingy. Wash them with clean water and a cloth and then apply a good coat of wax.
Old 06-03-2011, 05:20 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
get some wheel cleaner for chrome wheels (it should say do not use on alum. wheels) this will have acid in it
squirt it on and do some scrubbing with a green scrubby scotch brite and it will clean them right up
Removing Clear Coat from Aluminum jsarnold Body - Exterior 18 03-01-2010 02:54 PM
Removing paint from aluminum body trim TooMany2count Body - Exterior 3 10-27-2009 08:08 PM
Removing chrome finish from Cragar S/S wheels intergalactica Body - Exterior 23 12-20-2007 11:21 PM
Removing clearcoat from aluminum wheels Nitrousbutton Body - Exterior 5 10-01-2006 05:03 AM
Removing anodized aluminum coating Kermitt47 Body - Exterior 2 10-17-2004 03:17 PM
