Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing oxygen sensor
Old 06-26-2012, 03:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Lbacker
Slotted sockets *SNIP* will spring open and slip, ruining the hex head on the sensor.
It can, but not if you use a small diameter, wide as you can find (or doubled) hose clamp around the socket and over the cut-out. Same idea as what I do when attaching an oil pick up tube to the pump using my homemade driver:
