Removing piston from rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 10:12 PM
Chevy man owns stang's Avatar
Chevy man owns Stang
I have a 79 chevy dually with 454 I am rebuilding Engine. I would like to know how to seperate the piston from rod. I know its a stupid question so laugh but plz help
Old 05-10-2007, 10:23 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
If the components are stock the pin will need to be pressed out. for my small block chevy, I took a socket about the size of the pin in diameter and used a hydrualic press to get the pin out. Make sure the socket is smaller or else it will get cuaght up. This is the at home way of doing it. If your going to put em back together or reuse the stuffI would have a shop do it, I think they have specail equipment to do it and its precise. If their floating you just remove the locks holding the pin in and slide the pin out.
Old 05-11-2007, 06:45 AM
302 Z28's Avatar
It takes a pretty hefty hydraulic press to do it. Yes you can get them off at home, but good luck trying to get them back together. The piston pin boss must be properly supported to press the pin back in.
Vince
Old 05-11-2007, 06:53 AM
Wiki Edits: 31
some do it with the oven thing. that's how NAPA switched my pistions over.
Old 05-11-2007, 10:06 AM
302 Z28's Avatar
Yep there is a machine shop locally that does it that way. There is just something I do not like about seeing the wrist pin end of a rod glowing red hot.
Vince
Old 05-11-2007, 11:11 AM
johnsongrass1's Avatar
Race it, Don't rice it!
That's too hot. Find another machinist.
Old 05-11-2007, 11:38 AM
Last journal entry: PICTURE TEST
pistons
You do not really say what you want to save... The Piston, rod or both.. If you are going to install new pistons they need to be installed by a skilled shop. It's not something the average at home guy can do. So you might just as well take the piston/rod assembly to a local shop and have them do the entire switch, besides if you are doing a good rebuild you will want to re-size the big end of the rod. So removing the pistons is not really going to save any money. I have a package deal in my shop when i do the entire job and i would not really knock any thing off the price if the rods came in empty...
Vince, I have it to the point with my rod heater that i can just get a straw color ( about 350 with a temp stick) on the rod and not "STICK" any pins installing them. I have seen other shops make rods blue, and red...I have never seen any issues with this even thought all the tech books tell you not to do it...
Keith
Old 05-12-2007, 09:31 PM
Thanks
thanks fellas i'll let a machine shop handle it then
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
New engine with pivot piston inventor Engine 21 06-05-2011 09:51 AM
5.565 or 5.7 rods? JohnyR17 Engine 9 10-09-2010 08:17 PM
Why do shorter rods increase piston speed and vice versa? brian12c Engine 7 03-09-2005 10:41 AM
piston rods for 5.0 FoxThunder 5.0 Engine 4 02-22-2003 03:53 PM
