Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing and reinstalling a door skin
Old 07-10-2012, 02:37 PM
John68040's Avatar
John68040 John68040 is offline
I've seen plenty of threads on how to install door skins, but how do you save the one you're taking off? Everyone seems to suggest grinding the edge off to remove the lip, but I have to reuse the skin. It's for a Pinto so there are no available replacement skins, and it's the door frame I need to repair for the most part. The bottom edge of the frame started to rot and a little of the lip on the skin.
Is there a way I can peel the lip up to remove the skin?
Or am I going to have to cut it off? And if I have to cut it, how do I reattach it? Welding a new lip on seems like a pretty big amount of work, not to mention the possibility of warping the metal.
