Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing and reinstalling a door skin
Old 07-10-2012, 08:51 PM
John68040's Avatar
John68040 John68040 is offline
If I don't remove it, I'll have to peel the skin back and distort it to be able to weld the inner frame. I figure I'll just deskin the door and have the frame sandblasted (then epoxy it) while I'm at it. I have a couple other spots to fix on the door skin which would be easier with it off. A redneck shoved bolts in the seam and ran weld over it to keep the doors shut for a circle track. The door I needed was the only straight panel on the car.
