Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing and reinstalling a door skin
Old 07-12-2012, 01:17 PM
tech69 tech69 is offline
put up or shut up
that's totally a good candidate for a lower skin job or to just peel it back where needed. Peeling back the whole door is a lot of work. If you have a metal brake you're in business. the rest of the door inside is probably still good and if you see anything above the bottom of the door it's probably superficial and just on the surface due to gravity and water that will rest on the bottom of the door as opposed to settling on the side of the door above the bottom.
