Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing-Reinstalling Valve Springs - Help
Old 10-18-2007, 11:27 AM
engineczar's Avatar
engineczar engineczar is online now
To go along with what BBC has said when your doing a cylinder make sure the piston on the cylinder you're doing is at top dead center, that way if something happens the valve will only drop until it hits the piston and you won't lose it down the cylinder.
BSE Racing Engines
